Pump on Mains and Hot With Mains Regulator
Posted: Mon Apr 18, 2016 6:08 pm
I live in a block of flats. We have excellent (turn the taps on and stand back excellent!) cold mains direct into each property, no tanks in lofts etc. The hot is supplied via a copper immersion cylinder in each flat - the pressure being from a small header tank atop the hot tank. Hot pressure is next to useless, in fact, it is useless.
My neighbour has just had a pump fitted in his flat to boost the hot, and to achieve this had a regulator fitted to the cold mains inlet which I presume lowers the pressure at which it enters the pump. The pump is connected to both hot and cold supplies to his taps/shower.
My neighbour now has excellent pressure on his hot water, and cold.
I had quotes to fit hot water systems in my flat (unvented, pressured I think?) and the cost ran to £1500 to £1800. I was then thinking of going for a thermal storage solution as it is apparently a better system, and the cost went over £2000
My neighbour got his pump done at mates rates circa £200.
I was told I could have a pump fitted by a plumber who quoted me for the works above. Not allowed, illegal or similar words were used.
Facts please? I can't find the definitive answer on Google, only something about pumps which boost the supply of cold. I just want to increase the pressue of my hot water so I can take a reasonably pleasant shower instead of doing piroettes under a drip every morning.
Thanks.
Thanks.
