Help Finding Garden Tap Supplied by Garden Hose
GaryN55
by GaryN55 » Thu Jun 16, 2016 4:13 pm
My house has an outside tap at the front, but not at the back, which is where I need one, but there is no mains supply I can use, and in any event I don't want to drill through walls etc.
What I would like to do is run a hosepipe from the front tap round to the back garden and attach it to a tap at the back, but I can't find a tap that is fed by a hose and can be attached to a wall. Any ideas please?
And if anyone can suggest anything better I would be very grateful
Many thanks
lets have a look
Re: Help Finding Garden Tap Supplied by Garden Hose
by lets have a look » Fri Jun 17, 2016 6:32 am
You could use a 15mm isolation valve with a short piece of 15mm copper pipe and attach the hose with a jubilee clip or a 15mm washing machine tap and connect the hose union off the outside bib tap and connect the hose with a jubilee clip,
even better would be to use push fit pipe and fittings
GaryN55
by GaryN55 » Fri Jun 17, 2016 10:16 am
Thank you - I will look for the parts and try
It is currently Sun Jan 05, 2025 3:43 am
