Recommendation for a Good Heating and Plumbing Book
Jack79
by Jack79 » Mon Jun 19, 2017 3:55 pm
Recommendation for a good heating plumbing book.
What I want to do which may help with the choice of reading matter.
This will be a total new install.
I will have a pellet boiler.
Hot water tank (hoping unvented) 2 coils and a immersion heater back up. I coil to be used at a later date for solar water heating, the other one to the boiler to heat the hot water.
Valve to switch between hot water only and heating and hot water.
Radiators will have thermostatic valves
1 room thermostat
I think this is a very basic system, but I keep getting lost with the safety side:
Expansion tanks , pressure release valves and so-one
I’m fine at running the pipework soldering the joints and can follow a diagram and feel I have a reasonable understanding of plumbing. Just need some help with the design side of it so if you can point me to a good book that may help. As looking on the internet is a nightmare so may different options.
Jack
It is currently Mon Dec 30, 2024 9:58 pm
