No Hot Water
Posted: Thu Aug 23, 2007 12:31 pm
Sorry but Im lost. No Knowlege of plumbing, and no Im not a fiddler.
Tried to remove a radiator, to decorate the hall, but valve on the pipe is buggered and when i started to loosen the nut water went all over.
So re-tightend the nut and drained the system from the drining plug outside (turning off the mains tap first).
Then removed the radiator fitting blanking plugs to the feed pipes.
Turned Mains feed back on, All OK no leeks. Cranked Boiler up, Heating Fine, BUT, now the heating is ok BUT NO HOT WATER.
The Boiler ( Glow Worm Hide Away) Works fine on Heating Mode, But for hot water it runs for 2 minutes only then cuts off. and Hey Presto, No Hot Water. Been without it for a week now and my partner is getting a bit Hot herself, Like if she had a Gun I think I would be the first... Do i have a Air lock????????
HELLLLLLPPP
Any body please....................
:oops:
HELLLLLLPPP
:oops:
