Leaking Towel Rail Where Weld has Broken
Posted: Wed Nov 15, 2017 10:40 am
by sijohnlloyd
The weld has broken by the valve top left of radiator. can it be fixed with something? see pictures. Thank you
Re: Leaking Towel Rail Where Weld has Broken
Posted: Thu Nov 16, 2017 9:22 pm
by katoosh525
That 'looks' like stainless, so yes - it can be fixed by specialist welding.
How on earth did you manage to tear that?
To get you through till spring when you can have it removed and repaired properly - you may well get away with a high tech marine pu adhesive, such as 3M 5200 (https://www.makewoodgood.com/product/3m-5200-adhesive-sealant/. Eye wateringly expensive (but so are stainless rads), can be applied wet too. I would suggest putting a universal hose clip around that to assist in keeping the sealant in as well.
Of course, if it's not stainless it is probably just time to buy a new radiator and 'fix' it that way.
