Would Repair on old Black MDPE Effect Water Supply Pressure
Posted: Wed Jan 10, 2018 10:49 am
by kdavid123
From previous groundwork where an underground water supply pipe was damaged I have found that a repair has been made to the old black mdpe pipe by using push fit connectors,22mm reduced to 15mm with a 400 mm length of 15mm plastic pipe to join the pipes.
This will be rectified using the correct connections but out of interest,would the above mentioned repair affect the water pressure to the supplied building?
