Connecting into Old Telcon 1/2 Pipe Mains
Posted: Tue Mar 27, 2018 6:57 pm
by harburt
Hi all
I'm in the midst of replumbing my house and have discoverted this black plastic pipe running the water mains:
I am presuming it's an old imperial standard even though it seems identical to 22mm pipe. Are there any push fit or compression adapters that I could use so I could cut into this existing pipe to add in the bits I need? Or do I need to replace the lot?
It comes in off some 15mm copper coming from the stop cock as per below:
Can I just cut into that 15mm and rerun the whole lot (if necessary)?
Any advice would be amazing
Many thanks
