PTFE tape
Posted: Wed Sep 12, 2007 4:58 pm
Why would you put PTFE tape on the threads of a compression fitting ?
Sorry if it seems like a rant - but it really gets to me, as I see this done on many occasions and have seen a few posts in here suggesting this is what should be done.
The threads are only there to pull the body of the fitting and the nut together, compressing the olive/ring to the pipe. The water tight seal is made between the olive/ring and the body of the fitting.
So - you need to put the PTFE tape on the olive/ring. It's only male iron connections where you would put PTFE tape on the threads.
Any other plumbers/ gas fitters / heating engineers, come across this very perculiar way of trying to make a watertight seal ?
