Unvented hot water tank prv dripping from temperature and pressure valve
Posted: Sun Apr 19, 2020 9:32 pm
God evening,
Please see attached photos. The dripping is from the Redring temperature and pressure relief valve.
Anyone able to help me with this one please? I'm trying to work out if the valve is doing its job and so I have an issue elsewhere which is causing the valve to drip or whether it is eg a washer type issue and the valve (this Redring type seems a lot more expensive than other PRV's I've seen but they do not have the open needle eye piece at the end (hope that makes sense).
Many thanks
Many thanks
