Finding cartridge for a Blanco tap ...
Posted: Mon Jun 01, 2020 2:21 pm
by mike_bike_kite
The tap in my kitchen is 15 years old and needs a new cartridge. Unfortunately Blanco don't seem to stock cartridges for older taps (brilliant!). They said all taps apparently have different cartridges so I can't just use an alternative (insane!). Do all tap supplies do this? Is there anything I can do?
Replacing the tap is a major operation as the plumbing in that area is quite complex and requires various cabinets to be taken apart etc.
I'm told the tap is a Blanco Lido BM1040. Not sure if that helps.
Any help appreciated.
Mike
Re: Finding cartridge for a Blanco tap ...
Posted: Tue Jun 02, 2020 10:28 pm
Hi mbk
You need to remove the cartridge and see if you can find a replacement on line. Your search will bring up a number of suppliers who sell a range of different cartridges - make sure you measure careful.
Posted: Wed Jun 03, 2020 10:51 am
by mike_bike_kite
stoneyboy wrote:Hi mbk
The problem is to remove the cartridge I need to turn the water off for the house. I can see the wife allowing me to just change the cartridge but not to have the water off for days while I wait for a new cartridge :)
Is it still possible to buy mixer taps that just use tap washers? these cartridges seem to be a bit counter productive (and costly).
Posted: Wed Jun 03, 2020 11:11 pm
Hi mbk,
Yes standard mixer taps are available, you'll probably have to have cross heads and you'll need to check they are full turn operation (or similar wording).
Posted: Thu Jun 04, 2020 12:30 am
by mike_bike_kite
Many thanks.
I'll look for a tap like that for the replacement.
Have a good day.
Mike
