Plumbing for anthracite radiator pipes
Posted: Sat Aug 15, 2020 5:17 pm
by Nofydd
I have a new radiator finished in anthracite with matching anthracite valves and pipes. I need to plumb the flow and return to the anthracite radiator pipes.
I usually use solder joints but I am assuming soldering is not going to work on anthracite? I am thinking of using Speedfit (which I've never used before). Will Speedfit work on anthracite pipework? If not, will a compression joint work on it? What is the recommendation?
Re: Plumbing for anthracite radiator pipes
Posted: Sun Aug 16, 2020 10:49 pm
Hi nofydd
Anthracite pipe is just metal pipe painted, suggest you use compression fittings to ensure a sound seal in the long term.
Posted: Mon Aug 17, 2020 8:24 am
by Nofydd
Many thanks, Stoneboy. I will go with your recommendation.
Posted: Tue Aug 18, 2020 9:48 am
Hi nofydd
If you prefer Speedfit you could clean off the paint finish on the part of the tube that goes in the fitting, this will ensure a reliable joint. You may find that with compression fittings you have to clean off the paint finish anyway so that the olives will fit. Six of one half dozen of the other!
