Plumbing washing machine into closed loop
Posted: Thu Jun 10, 2021 4:28 pm
by supergibbon
Hi all,
Total novice here hoping for a bit of advice.
We have recently been renovating the kitchen and part of that involved re-jigging the mess of pipes that was behind the washing machine. It is now in a closed loop coming from the boiler upstairs, through the shower/toilet/bathroom and down, and the plumber left the tap taped up at a certain pressure (1) while the plasterer came in to do his thing (not the best picture for seeing things on-sorry!). The pipe goes through the wall to an outside tap at (2), has a waste pipe going out to the drain at (3) and goes into the wall and up at (5).
It would be good to get our washing machine plumbed back in for now so we don't have to keep spending a fortune at the laundrette, but all tutorials on plumbing it in I've seen just involve swapping a new machine's water pipe in at one point (where the old one was). So question:
If we turned the water off at (1), undid the joint at (4) and then attached the 2 water pipes that are on our machine (one's got a blue end, the other white and then there's a grey waste pipe) would that be it away as part of the loop? Or is that going to do weird pressure things or cause hot/cold water problems that we should just fork out and get the plumber back in for?
Any help would be greatly appreciated! Thanks :)
Re: Plumbing washing machine into closed loop
Posted: Sat Jun 12, 2021 10:34 pm
Hi supergibbon
The white pipe looks like it’s your mains cold. If this is correct buy a speedfit washing machine T and two inserts. Turn the water off at 1, cut the pipe and fit the T, connect the blue hose to this.
Buy a cap to seal off the white hose end, it is unlikely that you will need a hot fill. Connect to the waste pipe using a washing machine upstand.
Job done..
Posted: Fri Jun 18, 2021 7:54 pm
by supergibbon
Thanks for replying Stoneyboy (and apologies for the late return of one)! That all seems very do-able - didn't think it'd be a massive job but didn't want to just mess around with it before asking just in case. Will give it a go and see how we get on : ) Cheers!
