Mains booster pump for 10.5kw electric shower
a9blue
by a9blue » Tue Dec 14, 2021 7:08 pm
For a 10.5kw electric shower. Will it make a difference or is it not something you should do?
Re: Mains booster pump for 10.5kw electric shower
by stoneyboy » Thu Dec 16, 2021 9:16 pm
Hi a9blue,
Generally electric showers are designed to work with constant mains pressure of a minimum 1-1.5bar depending on the manufacturer. It will depend on the type of booster you are proposing, most cut in when flow is detected so if you have say 0.5bar mains it is likely that your shower will turn off because of low pressure before the pump activates.
It is currently Mon Dec 23, 2024 1:28 am
