garden tap not working
Posted: Wed Dec 21, 2022 8:58 pm
by terry004
I forgot to lag my garden tap and after the bad frost we all had I turnt my garden tap on and all I get is a trickle of water I have tried putting heater inside cupboard as well as hot water over the tap with no luck...anyone got any ideas...they would be much appreciated.
Re: garden tap not working
Posted: Thu Dec 22, 2022 9:48 pm
Hi terry2004,
You could take the tap apart and replace the washer but quickest and easiest to replace the tap complete which will cost around £6.
Hi terry2004,
You could take the tap apart and replace the washer but quickest and easiest to replace the tap complete which will cost around £6 if you diy.
Posted: Fri Dec 23, 2022 2:43 pm
by terry004
thanks for the reply I think I will replace tap..
Posted: Fri Dec 23, 2022 9:46 pm
Hi terry004,
If the existing tap has a non-return valve this will have been deformed by freezing so replacement is the simplest option.
Posted: Sat Dec 24, 2022 12:08 pm
by terry004
Thanks for the info how do I know if it has a none return valve
Posted: Sun Dec 25, 2022 9:28 pm
Hi terry004,
If you look at the body of the tap if there are two screws underneath prior to the main body of the tap then there is an NRV.
Posted: Thu Jan 12, 2023 3:24 pm
by Drip-Doctor
If the tap has a plastic check valve inside its probably that which is stopping the tap from working. prise out all the plastic and the little spring and refit. Not strictly legal as it should have the check valve but it will at least work.
Worth investing in a tap cover. I like the pyramid ones that seal against the wall.
