Plumbing
Posted: Thu Nov 08, 2007 3:06 pm
by JimJam
I have downloaded and read your advice on how to clear an air lock in a hot water system. BUT, does anyone know where I can obtain hose with a 20cm. internal diameter to carry out this process.
JimJam[color=red][/color]
Posted: Fri Nov 09, 2007 7:09 am
by bobplum
20 cm or 20mm 20 cm seems large for a hose
Posted: Fri Nov 09, 2007 2:27 pm
by JimJam
To Bob Plum. Sorry got my sizes wrong its 20 mm dia.not 20cm.
JimJam
Posted: Mon Nov 12, 2007 4:40 pm
by JimJam
Where can I purchase a hose toconnect to 20mm taps to clear an airlock in the hot water system
JimJam :?:
Posted: Mon Nov 12, 2007 7:55 pm
by bobplum
from what i can guess are you going to force cold water thru the hot water system if so any hose will do just use a jubilee clip to tighten or if you a have a mono tap ie in the kitchen put your hand over the outlet turn open the hot tap first then the cold on full power ,hand over the outlet and this may work
