gap between showr tray & wall
Posted: Sat Dec 01, 2007 10:08 pm
I'm fittin a 800mm square shower tray. There are brick walls on two sides & a stud wall on the other, the left. The shower head is mounted on the right hand wall. The studd wall is lined with marine ply.
If i move the tray snug up against one wall, then I hae a gap of approx 25mm between the tray and the other wall.
Any suggestions ..?
1. I could split the difference and have a 1/2 inch gap with side. The tiles will be approx 10-12 mm thick and I could try & sdeal the remaining gap with silicon. I don't like this idea.
2. I could move the tray snug up against one wall, fill the gap with either wood or expanding foar, then cut tiles 30mm inch wide and silicon them in place to cover the 25mm gap & give a 5mm overlap with the tray. I'd then tile as normal up the wall. Which wall should I do this on - the right hand one under the shower head? or the left hand one on the other side?
3. Board the complete wall with an extra 1/2 inch board to halve the gap- seems a lot of work.
Any other ideas please?
Steve
Any suggestions ..?
Steve
