Plumbing Showers in to a wall
Posted: Wed Jan 09, 2008 12:21 pm
I have the task of installing a mixer shower and the mrs doesnt want any pipes visible.
My only option is to cut a hole in the stud wall where the shower will be and run the pipes on the inside of the wall before repatching and tiling over.
Will this pose any issues with regards to what types of mixers I will be able to fit behind the tiles? Ideally I want a mixer tap that is inset in to the wall. Will there be enough room inside the stud wall for such or am I better with something that is ugly and surface mounted?
I intend to put a hole in the wall big enough for me to fasten some more battens and supports for the shower to be secured to so it should be quite sturdy and if I need to get to the piping, then I will go in through the other side and not damage the tiling.
Novice Alert!
Novice Alert!
