Worcester flue accessories
Posted: Fri Jan 25, 2008 2:35 pm
by m7ohn
What's the difference between a 90 degree bend and a 90 degree elbow as used on a vertical flue system?
Marcus
Posted: Fri Jan 25, 2008 9:34 pm
by bonzo
Both the same thing. They only do one type of 90 degree fitting as far as i know
Posted: Fri Jan 25, 2008 10:05 pm
by m7ohn
Bonzo, been studying the Worcester website and they do two 90' bends.
one type has a socket and rubber seal on both the flue gas inner pipe and the air intake outer pipe - part number: 7716191084
the other type has only a socket and rubber seal on the inner flue gas pipe and the outer pipe has not got a socket and is secured to the mating pipe by a metal twin screw sleeve. - part number : 7719002348
seems like both will do the same job??
