Open vented heating system
Posted: Sat Feb 02, 2008 11:28 am
by Jamest
Hi All,
Could anyone tell me if i need to drain an open vented system to replace a radiator valve?
I tried freezing the pipes but with no luck as the amount of pipe i'm able to get to coming from the floor is not enough. :cry:
Many thanks in advance
James
Posted: Sun Feb 03, 2008 4:31 pm
by dcc
aye youl have too drain down the system to replace it.
when you tried freezing it, was the pump, boiler ect off? because its impossible to freeze water when its moving
Open vented
Posted: Sun Feb 03, 2008 4:58 pm
by Jamest
Thanks for your reply i was afraid of that.
Yeah all was turned off no heat and no pump on, the problem with it is the pipework only shows by about a inc and half so not enogh to freeze.
Many thanks
James
Re: Open vented heating system
Posted: Sun Feb 03, 2008 6:47 pm
by muttley
[quote="Jamest"]Hi All,
James[/quote] You could bung the F&E tank.No need to drain then,you might get a small weep but you should be able to handle it :wink:
Posted: Sun Feb 03, 2008 11:03 pm
by chris_on_tour2002
[quote]You could bung the F&E tank.No need to drain then,you might get a small weep but you should be able to handle it[\quote]
wouldn't you have to bung the expansion pipe as well muttley? otherwise air will get into the system and it will drain, gushing out when the valve is removed
