Cold Water Tank Removal
Posted: Tue Feb 19, 2008 12:34 pm
by ananab_00
I'm considering converting my attic. It would only be worth doing if we removed our cold water storage tank, is this a big job and will it cost a lot?
thanks
Posted: Tue Feb 19, 2008 4:58 pm
Removing the cold water tank - compared to coverting a loft wont cost alot.
What does the tank feed ? does it feed the heating system ?
or is it the cold storage for the bathroom taps - if it is could you get rid of the tank altogether and have mains cold water to all taps ?
Removing the tank should be easy enough - and can be done by a capable DIYer - if that's you, it wont cost anything to remove.
Posted: Thu Feb 21, 2008 4:26 pm
by britkat
I am also looking to remove my cold water tank.
I have an old back boiler servicing my hot water (with immersion HW tank to top up the temp).
Did I read somewhere that I cannot use a cold mains feed with my back boiler?
If I can do I just connect together the incoming cold feed and the outgoing frm the tank?
Posted: Thu Feb 21, 2008 10:08 pm
Mains cold water will fill a tank that will provide the water for the hot water and for the heating water. You cannot connect mains cold water directly to a back boiler.
That's why I asked what it feeds - if it feeds the heating then no it cannot just be removed - unless you change to a combi.
If it is for the cold water supply to the bathroom taps - then yes it could be removed then you could connect mains cold water to all taps.
Posted: Fri Feb 22, 2008 8:53 am
by britkat
Thanks for the reply. I believe it feeds the backboiler.
I guess I'll need to leave it for now, until we upgrade to a condesing combi.
