Fit Radiator or Tile first?
Heeber
by Heeber » Fri Feb 22, 2008 12:32 pm
Hi folks,
redoing bathroom and am planning on replacing the existing radiator with a heated towel-rail type (will match BTU, etc).
I've never mounted one of these before, so (apart from the pipework to valves), is it better to fully tile the walls, then drill & mount the radiator - or should I mount the radiator first and tile around.
Many thanks,
Heeb
ALDA
by ALDA » Fri Feb 22, 2008 3:57 pm
Tile first. Much neeter apperance. Less fiddly.
by htg engineer » Fri Feb 22, 2008 4:10 pm
It's best to tile first then fit towel rail later.
If it's a ladder type towel rail, you will be able to see the tiles behind - if there's all little cuts and patched bits around the brackets etc - it wont look very good.
It is currently Thu Feb 06, 2025 6:35 am
