low hot water pressure mixer tap
Posted: Sun Mar 09, 2008 2:23 pm
by georgem
I have low hot water pressure thro' bath mixer tap, has been like this from new, new build. Water pressure from sink next to bath is OK. Water pressure from sink in en-suite next door has OK water pressure, as does downstairs taps. Sink next to bath produces at least four times more hot water in volume per same time, measured when trying both taps separately. Someone has suggested fault is at mixer tap - circlip bent/twisted and requires repairing/replacing? thoughts on this?
suggestions/comments appreciated
George :(
Posted: Sun Mar 09, 2008 9:39 pm
by sjlheating
certainly sounds like a faulty tap though it could be that the tap itself requires a higher pressure of water than is being received. newer taps and imported taps often require higher hot water pressure than is given in a traditional gravity system...more adept to combi systems
Posted: Sun Mar 09, 2008 10:26 pm
by chrisroberts
is the hot water supply to the mixer a flexi pipe, if so it may have been twisted on installation. make sure there is no kink in it that would restrict the flow.
Posted: Tue Mar 11, 2008 8:33 pm
by georgem
[quote="chrisroberts"]is the hot water supply to the mixer a flexi pipe, if so it may have been twisted on installation. make sure there is no kink in it that would restrict the flow.[/quote]
thanks for the reply
hot water supply not a flexi pipe
blockage? jiggered tap? been advised it may be a twisted/slipped circlip on tap?
bit frustrating as it has been like this since new, very slow/low fill rate to bath
George
Posted: Thu Mar 13, 2008 12:07 pm
by bobplum
[quote="georgem"][quote="chrisroberts"]is the hot water supply to the mixer a flexi pipe, if so it may have been twisted on installation. make sure there is no kink in it that would restrict the flow.[/quote]
George[/quote]
sounds like the wrong taps for the system
bob
Posted: Thu Mar 13, 2008 12:08 pm
by bobplum
hi sounds like the wrong taps for the water system
bob
Posted: Mon Mar 17, 2008 8:56 pm
by rock chicken
As the pressure has been bad since you bought this new house, it sounds to me that it could be some grit/flux/debris stuck in a mesh filter somewhere in the tap. There may be one on the end of the spout which can be taken off with a spanner. Failing that, there may be one in the tap body. Hope thats some use to you.
