water temp and pressure loss
6 posts   •   Page 1 of 1
armytouch
by armytouch » Sat Mar 22, 2008 11:12 pm
hi,hope you can give me some suggestions why the water temp keeps going up throughout the system and i am lossing water pressure.
thanks
by htg engineer » Sun Mar 23, 2008 9:06 am
Boiler type, make model ??????
Water pressure to taps or heating system
More information please
armytouch
make n model
by armytouch » Mon Mar 24, 2008 8:30 pm
hi its a baxi 105 model boiler,been told it crusty round some connections,the loss in pressure is boiler pressure so i am thinking leak around boiler connection with connectors been crusty,would this affect the water temp? thanks
armytouch
water pressure dropping
by armytouch » Wed Apr 02, 2008 11:11 pm
Hi,the water pressure in boiler keeps dropping,but then when topped up,the pressure will build up and overflow.
The boiler is set on timer but comes on in middle of night when not timed to come on ,any ideas.
cheers
by htg engineer » Thu Apr 03, 2008 11:37 am
The problems are not related.
The problem with the pressure loss, will be with the leaks you have described the joints should be broken, new fibre washers and joints re-made.
The pressure rising could be the plate heat-exchanger has corroded and the hot water and heating water will be mixing. With you having problems with the hot water temperature I am pretty sure the problem is with the plate heat-ex and not with the expansion vessel.
As for the heating coming on when not set to come on at that time, is either
a fault on the programmer
You're not using the timer properly
There is a frost stat on the boiler and it is coming on during the night when the temperature drops (i'm guessing this, as you have only said it comes on at night)
Hope this hepls
armytouch
thanks
by armytouch » Thu Apr 03, 2008 11:01 pm
Like to say thankyou for your help,i found a small leak from one of the rads,hopefully this will keep pressure up.thanks
It is currently Wed Jan 08, 2025 6:00 pm
