Cistern not refilling
Posted: Wed Mar 26, 2008 7:29 pm
by Mike Dovey
Up stairs bathroom
Sink and bath water pressures all ok but the cistern will not refill
Posted: Wed Mar 26, 2008 11:30 pm
by redkev
i would say, check the iso valve if it has been turned off for any reason incase it has stuck shut.
u could try unscrewing the nuts at specific points to see if water is flowing through. or could be dirt in the inlet valve. or the inlet valve may just need replaced.
common fault. i have done 6 this week only.
Posted: Thu Mar 27, 2008 1:02 pm
by Bungler
If flow from taps is OK & no one's been messing around closing isolating valves then perhaps cistern fill valve may be stuck in closed position or clogged with scale or other debris. Might be possible to free it up though - push ball float down if its stuck in the "full" position and if water doesn't flow, try pulling valve activator outward. If nothing happens, unscrew the valve body slowly till water (hopefully) starts leaking out.
Sorry if this is too obvious a solution & you've already tried it.
Posted: Fri Mar 28, 2008 2:48 pm
by nitro23456
If you can't be bothered to type out your problem properly, I cant be bothered to solve it for you.
No need to get shirty nitro..... The doctor3
