Roofing insulation regs
Posted: Wed May 06, 2009 9:04 pm
Hi there.
I purchased a new build property 4 years ago and ever since I've had problems with leaks both inside and outside down from the front wall. I've complained to the developer countless times and had some work completed such as the sealing of the rooflights but still I'm plagued with leakage. Without going to a lawyer with enough proof I'm a little stuck! To make matters worse even NHBC wouldn't insure it!
The property is very different in that the roof is a curved metal sheeting with two Velux roof lights.
There is no loft or attic and no space between the roof and ceiling. I have my suspections that there is no waterproof membrane between the ceiling and metal sheeting, basically when I took out a ceiling light fitting I could touch the underside of the metal roof!
My main question is, should the developer had used a waterproof membrane or something similar that would provide an extra layer of protection by law?
I've put a couple of link to pictures etc:
http://www.mrpugster.ukfsn.org/house/water_damage7.jpg
http://www.mrpugster.ukfsn.org/house/outside_wall3.jpg
http://www.mrpugster.ukfsn.org/house/water_damage6.jpg
The Velux's have now been sealed with fibre-glass material but look really unsightly so I'll also be looking for some decent material I can use around the windows if anyone has any bright ideas?
http://www.mrpugster.ukfsn.org/house/velux2.jpg
Any help is greatly appreciated.
