Can move slates inside roof space
Posted: Fri Nov 18, 2011 9:44 pm
by Hayct
I have just had my roof re-slated and I find that a lot of the slates feel loose/floppy under the sarking. I suspect that roofer has made a mistake with the spacing of the battens. If I ignore this what are the long term effects likely to be. The problem is complicated because I am now having solar panels installed.
Re: Can move slates inside roof space
Posted: Sat Nov 19, 2011 1:11 pm
by welsh brickie
you could sprayfoam the area to secure the slates,you can purchase it from www.expandingfoamkits.co.uk
or have company install it for you.
If you leave it, strong winds could dislodge the slates and make it hard to repair because of the installed solar panels.
Posted: Sat Nov 19, 2011 3:34 pm
by Hayct
Thanks for that. If I had it sprayed with foam would the sarking have to be cut back?
Posted: Sat Nov 19, 2011 8:20 pm
by welsh brickie
its best to remove all the sarking, so that the foam has the best chance to adhere to as much surface as possible.
