Advice on how best to complete Chimney Capping to install an electric fire in the fireplace
Joona
by Joona » Thu Feb 20, 2014 11:29 am
We are currently privately renting our house and have plans to decorate and possibly install and electic fire place into an open brick fire place, what i need to know is is it best to cap the chimney off at the top to help prevent heat loss and wind and rain getting in or would a chimney baloon do the same job.
DIYDoctor2
Re: Advice on how best to complete Chimney Capping to install an electric fire in the fireplace
by DIYDoctor2 » Mon May 19, 2014 1:20 pm
See the answer to this in DIYDoctor's project section - and as you are tenants you should ask for your landlord's permission in writing before you start.
Closing a Fireplace
A fireplace, which is not used anymore, can be successfully closed to allow more wall space…
The insertion of an air-brick is required in the closing of the fireplace to allow air to circulate . . . more at https://www.diydoctor.org.uk/projects/fireplace2.htm
It is currently Tue Jan 07, 2025 12:22 am
