Enclose Asbestos Soffits With PVC?
greengrass
by greengrass » Fri Nov 10, 2017 10:17 pm
Advice should it be removed even though its sound: Asbestos enclosing underside of soffits and 4 Gable end barge boards. Haven’t had estimate yet but guess It’s a cost more than I can currently afford to remove.
Therefore the question is to enclose each area with PVC cladding yes or no?. I’ve worked out a bracer bracket across The brackets will be cranked 90deg each end, opposing cranks, one up to fit on existing facia/barge board the other end facing down to fit on to wall so no drilling in to asbestos. Can't seem to get right size drawing attached.
Many thanks to viewers and responders .
It is currently Wed Jan 08, 2025 10:06 pm
