Mounting a 9kg Projector Screen
Posted: Thu Oct 03, 2019 6:58 pm
I have tried and failed to mount a projector screen and really need some help now.
I initially fixed the mounts directly to the wall, into masonry on the left but sadly there was only void on the right and I couldn't get a fix. I used 80mmx5mm multi-material screws and red rawl plugs.
I then decided I would batten with Dogs Bolx adhesive and tried 100mmx5mm multi-material screws into the same plugs but then couldn't get a fix on either side.
Can somebody advise what the best way to get this up is.
I now have existing holes and am thinking that I can use them for the screen mount screws as the screws are longer than the batten anyway. For fixing the batten I am thinking of drilling 2 new holes on the left, 2 new holes in the middle, both into masonry and using 80mmx5mm multi-material screws and red Rawl plugs but what do I do about the right where I can't get a fix? The masonry appears to 100mm into the wall meaning there is 75mm of void and then 15mm of soft wood that the 10mm of plaster is mounted to.
Please help!!!
Please help!!!
