Pre Drilling Drive Screws for Corrugated Roofing?
babybio
by babybio » Wed May 06, 2020 3:33 pm
I need to replace a section of corrugated bitumen roofing on my garage after the old sheet blew off in a storm.
The sheets are fixed with 'drive screws' with plastic caps. The drive screws are 75mm x 5mm.
Do I need to pre drill holes into the wood or can I just hammer the drive screws in?
thanks
Re: Pre Drilling Drive Screws for Corrugated Roofing?
by stoneyboy » Wed May 06, 2020 10:07 pm
Hi babybio
It is advisable to drill a clearance hole to allow for expansion and to minimise the risk of cracking the new sheet.
babybio
by babybio » Sun May 10, 2020 12:59 pm
Thanks for the reply. I think I may not have been clear. I meant whether I need to pre drill the wood purlins that the drive screws will go into.
If so what size of hole is suitable for a 5mm nail?
thanks again.
by stoneyboy » Sun May 10, 2020 10:41 pm
Hi babybio
Suggest you use a 4mm drill.
It is currently Tue Jan 07, 2025 1:29 am
