Chasing cable from under stairs to stud wall above
Posted: Tue Jul 07, 2020 2:51 pm
by rmg47989
Hi all hope you can help!
I am in a new build property and looking to move my virgin router upstairs. instead of chasing cables along the wall i would like to do this cleanly.
The cable is located underneath the stairs, which has a stud wall to the front - directly above this wall is the stud wall in the room where i would like the cable to go.
I have cut into the office stud wall and can see the wood beam to the bottom, would this be as simple as drilling with a flat wood bit through and feeding a wire/rod down to a opening in the bottom stud wall?
Re: Chasing cable from under stairs to stud wall above
Posted: Wed Jul 08, 2020 10:38 pm
Hi rmg47989
Yes it should be but beware there may be screws or nails to drill through and there may be cables and pipes between the ceiling and floor above.
