Lead lined roof gutter valley leaking
DJB
by DJB » Mon Aug 02, 2021 11:17 am
I have a lead lined gutter valley with a pitched slate roof on 3 sides, which exits into a hopper above a down pipe.
It is leaking into the house through the lead overlap.
I've had 3 roofers look at it and they all give different advice.
One said paint it all with Aquapol, but didn't know if it would crack when walked on for roof maintenance.
One said just paint over the lead overlaps with Aquapol so I could just step over the overlaps for maintenance.
And one said solder all the lead overlaps and cracks.
I would have liked to line over the lead with EPDM rubber but they all say EPDM doesn't stick to lead. There must be an adhesive out there that would, or could EPDM be layed over loose?
Advice please.
Bertie Bumwhistle
Re: Lead lined roof gutter valley leaking
by Bertie Bumwhistle » Sun Aug 15, 2021 6:06 pm
Hi there,
I spotted the info on the link below when I was looking at EPDM for upgrading my dormer flat roof. Hope its of use to you.
https://www.rubber4roofs.co.uk/rubber-gutter-linings
JoelPip123
by JoelPip123 » Mon Sep 13, 2021 12:40 pm
You will need an adhesive to make sure the EPDM sticks to the lead, though the general advice is that adhesive to lead is not always successful, as there is often an oxidised layer.
It is currently Sun Dec 22, 2024 7:57 am
