candy cic60 condenser tumble dryer
Posted: Wed Feb 18, 2009 2:17 am
by ptg1174
hi my candy cic 60 dryer keeps triping my house electric everytime i plug it in i had a problem with no heat and replaced thermal fuse which did the trick but now it keeps triping and is a real pain would love to repair rather than replace please help
Posted: Sat Feb 21, 2009 6:52 am
by wimiu012uk
You say it keeps tripping.
When it trips does it then trip the house electrics ?
If the dryer keeps tripping you may of installed the wrong stats for the machine as there are several ones availiable, check that you have bought the right ones.
If it trips the house electrics when plugging in check the plug as some wires could have broken causing a short.
Posted: Wed Feb 25, 2009 1:05 am
by ptg1174
correct part fitted bought from maplins, it does keep triping house electric
the plug is a sealed plug i will try changing it
Posted: Thu Feb 26, 2009 1:28 am
by ptg1174
changed plug same result when plug in it still trips house electrics ?
