rechargeable toothbrush
Posted: Thu Mar 05, 2009 9:00 pm
by yorksvilla
Can I use a shaver socket (230v UK) in the bathroom to charge an electric toothbrush. Any special wiring required if socket is suitable?
Posted: Fri Mar 06, 2009 10:33 am
by acsimpson
My electric toothbrush charger has a shaver plug on the end and runs at 240v so that would be fine.
I guess if you have a normal plug on the charger then you'd need to use an adapter but check the ratings on the plate and charger to make sure it wont be overloaded.
Posted: Fri Mar 06, 2009 4:22 pm
by kbrownie
Hi yorksvilla,
Manufactures instructions should be followed. but if you used a two pin adapter, as standard shaver sockets are
seperated extra low voltage. which means the voltage supplied to your property is stepped down at this point to twelve volts. I would say it would be safe to do so.
KB
