Neff B1421 electric oven
john9159
by john9159 » Mon Dec 21, 2009 9:01 am
I am about to replace a thermostat which I think has been the cause of power supply tripping in the house.
This diagnosis was made by someone more experienced than myself so I hope it will solve the problem.
If the problem persists, can someone tell me of any other possible likely causes.
Thank you.
collectors
by collectors » Sun Dec 27, 2009 6:47 am
The stat is a possibility for tripping (i assume the RCD). But i would personally check the heater element as well, as these tend to be the 1st thing to create problems in most ovens & are quite often cheap to replace with an after market one. .
It is currently Tue Nov 26, 2024 5:33 am
