Hygena Built in Single Gas Oven Mains Ignition Fault
Skid Sprocket
by Skid Sprocket » Tue Jan 02, 2018 10:25 am
I have a Hygena built in single gas oven that blows the 13 amp fuse when plugged in. It blows even before the oven control is turned. New ignition units are available but not sure this is the cause. I have checked the main cable from plug to the terminal block are there any other meter checks I can do?
It is currently Mon Nov 25, 2024 12:01 am
