Bathroom Tiling - Advice on prep and tiling onto wood
JamieTB
by JamieTB » Sat May 17, 2014 7:31 pm
Hi guys,
Sorry if this is a stupid question and been covered before. I tried to search but couldn't find the answer.
I'm ready to start tiling our bathroom but one of the walls has a wooden frame I've put into it to hold up a heavy wall mounted sink and mirror cabinet. Can I tile straight over the wood? I wasn't sure as I know plastering over wood isn't good so not sure about tiling.
Also in terms of prepping this wall, should I fill the cracks around the edges of the frame first and smooth the wall over? If so what would I use?
Thanks in advance for any help, I've never done this before so any advice would be really great.
Thanks,
Jamie.
Re: Bathroom Tiling - Advice on prep and tiling onto wood
by welsh brickie » Sun May 18, 2014 11:23 am
use dry wall screws and fix galvanized or stainless steel mesh to the wood,
plumbbob
by plumbbob » Sun May 18, 2014 11:27 am
There are two options here.
It wouldn't be a problem tiling over the wood providing the tiles are large enough to bridge the wood. If you have a small border in the tiles there is a slim chance the different materials may cause problems in the form of grout cracking.
Why not stick a sheet of 9.5mm plasterboard over the whole area and tile on to that?
JamieTB
by JamieTB » Sun May 18, 2014 10:43 pm
Thank you both for your advice. There are some thin border tiles that are likely to run straight up where the wood is so I think I'll put a sheet of plasterboard up like suggested.
Thanks,
Jamie.
It is currently Thu Dec 05, 2024 1:59 am
