Fixing wall panel for shower enclosure
Posted: Sun Feb 07, 2010 11:26 am
I am considering using 1900X850 plastic wall panels (with a tile pattern) inside our new shower enclosure. They are sold by B&Q and demand that you should use only'evostik nail & seal adhesive' to keep their guarantee.
I am concerned that this type of adhesive means that you cannot move the panel once it has been put on the wall. This means that any mistake in positioning has serious consequences!
The other issue is that one side of the enclosure has a recess which means cutting the panel very accurately and then even trickier positioning.
Can I use any other adhesive which allows some initial movement or should I consider using ordinary tiling?
Thanks Jem
Thanks Jem
