Problem using self drills for fixing to plasterboard
Posted: Sun Jun 26, 2011 9:35 am
Hi Folks
This is my first post here so hello to you all.
I have used the self drills, similar to Redidrive, a few times and have found that once you have screwed in the the self tapping section section into the plasterboard and offered up the lightweight fixture and then screwed into the plasterboard, that you are then unable to remove the screw alone without the whole lot coming out resulting in the hole not being reusable.
I do not know if this is a common problem or not.
I have two questions to ask.
Is the way around this to grease the screw before inserting, and if so what type of grease/ lubricant would be best?
Now that the self tapper part cannot be reinserted into the hole and the fixing must go in the exact same place, are there any alternatives to using glue to attach the metal fixing to the plasterboard walls.
I am aware of a repair kit offered by a manufacturer, but not sure if I can name it on this site, where you can insert a plastic rawlplug into the hole after wrapping it with certain material. I wonder if anyone has used it?
Any help would be appreciated.
