Fixing Stair Handrail to Plasterboard Stud Wall Securly
Posted: Wed Sep 09, 2015 3:21 pm
by DaveyT
I would like to fix a stair handrail to a plasterboard (stud) wall. Are there any fixings that would be strong enough to take the weight?
Re: Fixing Stair Handrail to Plasterboard Stud Wall Securly
Posted: Wed Sep 30, 2015 2:58 pm
by thedoctor
Ultimately, the strongest fixing when fixing to a plasterboard surface is to fix into the stud work behind it so this is really the best way to go. You can fairly easily locate the studs using a stud finder (https://www.diydoctor.org.uk/DIY-superst ... ctors.html) and screw each of the banister fixings through the plasterboard surface into the stud.
As said, this is certainly the best way to go to ensure a secure fixing
Kind Regards
Posted: Mon Jan 11, 2016 12:55 pm
by ShelfMaster
thedoctor wrote:Hi
Ultimately, the strongest fixing when fixing to a plasterboard surface is to fix into the stud work behind it so this is really the best way to go. You can fairly easily locate the studs using a stud finder (https://www.diydoctor.org.uk/DIY-superst ... inder.html) and screw each of the banister fixings through the plasterboard surface into the stud.
Kind Regards
I get a 404 link not found on that link. I'm trying to find where the studs are located behind plaster board too.
Posted: Mon Jan 11, 2016 5:06 pm
by thedoctor
Apologies for that, I have now fixed the link for you to our range of stud sensors
Hope this helps
