Hanging a 49 Inch TV on Chimney Breast
Posted: Mon Aug 15, 2016 9:11 pm
by zante1956
going to hang the tv on the chimney breast wall that is plastered a solid wall . what is the best way to do this ie there is no fire at the bottom off wall take it there will be no pipes or cables running between chimney wall
thanks all
Re: Hanging a 49 Inch TV on Chimney Breast
Posted: Tue Aug 16, 2016 6:43 pm
by welsh brickie
use a 6mm concrete fixing screw, 70mm long , no rawplug required.
Just drill a 6mm hole with your masonry drill, then using a Torx bit, put the drill in the slowest setting and slowly screw it in the wall.
No I doubt if there is any pipes or wires in the breasting, but you can hire or buy a detector, to be on the safe side.
