Fixing to Plasterboard Using red Plastic Wall Plugs
Posted: Fri Jan 18, 2019 3:30 pm
Hi I am new to DIY and just wanted to know if i would be able to use the red plastic wall plugs in plasterboard.
I would like to fit some single coat hooks up to a plasterboard wall using the 6mm red plastic plaster board plugs. I was told at B&q that they would not be suitable as it would not make a strong enough anchor in this type of material, however I read online that the red plastic rawl plugs can be used for plasterboard.
Has any one used the red rawl plugs for fitting to plasterboard walls? My wife only plans to put her coats etc on the hooks so I don't imagine that it would be a problem. Is there a weight limit for these plugs on a plasterboard wall.
Also as the holes for drilling screws are quite close together on these hooks, I was wondering if this might cause a problem. As I will need to drill holes and put plugs in quite close together, I am worried that the hole might break through into the other one, or the plugs might not up against on another at the back of the wall. Would there be any issues to drilling and putting these wall plugs close together?
I have put some pictures of the hook and type of plugs screw I plan to use.
Many thanks,
Jamie
Many thanks,
Jamie
