Vertical Roman Blind Swivel Fixing Loose
Posted: Sun May 03, 2020 9:25 am
We had some vertical Roman blinds fitted approximately 3 years ago but 1 of the swivel fixings has worked loose. The one side that has worked loose has used a 30mm Redidrive wall plug to screw into. Can i just use a larger Redidrive plug to screw into to fix the problem.
Many thanks
Andy
Many thanks
Andy
