Plasterboard at least 40mm thick in kitchen?
Posted: Thu Jul 09, 2020 11:48 am
by DroopDiyDoctor
The hole
The hole
[img]
I started putting a wall kitchen cabinet up yesterday.
I was going to use Blue 25mm GripIt fixings but I found on drilling the 25mm hole that the plaster/plasterboard went back at least 40mm (I didn't want to go any further.
Obviously I can't use the GripIt fixings and being somewhat of a novice I am a bit confused as to why I came across 40mm+ of plaster. Could anyone enlighten me and more to the point what I should do moving forward with regards to filling the big hole I now have and what fixings I should now use.
Many thanks
Re: Plasterboard at least 40mm thick in kitchen?
Posted: Fri Jul 10, 2020 7:20 pm
hi droopdiydoctor
If you have a plasterboard wall you've probably drilled into one of the dot and dab positions.
Posted: Fri Jul 10, 2020 10:23 pm
by DroopDiyDoctor
Thank you S,
Would you be able to advise me as to what I should fill the hole with and what fixing I should use?
Many thanks
Posted: Sat Jul 11, 2020 11:02 pm
Hi droopdiydoctor
Fill the hole to within 5mm of the finished face with some plaster, let this set then do a top coat.
If your walls are plasterboard the corkscrew type fixing will be ok. Where you have filled, drill a hole and use a standard plastic plug.
Posted: Sun Jul 12, 2020 7:35 pm
by DroopDiyDoctor
Thank you for your help and advice.
