Advice on choosing screws for bookshelves
Posted: Wed Mar 10, 2021 3:49 pm
by SighMartini
Hi there, I've been googling but I seem to be getting more confused.
(https://www.ikea.com/gb/en/p/bergshult- ... s99290623/)
I am hanging 120cm particleboard IKEA bookshelves with 3 brackets into brick masonry and I can't work out what size screws and wall plugs to use. Ideally they'll be bearing two layers of books so they'll need to be strong.
I have an impact drill and I've hung a couple using 40mm screws/plugs and they feel secure but now I'm worried the screws are too short?
Many thanks
Re: Advice on choosing screws for bookshelves
Posted: Thu Mar 11, 2021 9:44 pm
Hi sighmartini
It looks like you will be loosing 20mm of the screw length in the bracket so suggest you go for 60mm screws.
Posted: Fri Mar 12, 2021 1:02 pm
by SighMartini
stoneyboy wrote:Hi sighmartini
Ah, good point. Any recommendation for the screw gauge, drill bit size and plug size? I'm drilling into brick with a layer of plaster on top
