Wooden batten for curtain rail
abctc
by abctc » Sat Jan 13, 2024 9:50 am
Hello
When drilling holes in the wooden batten for the curtain rail brackets, the batten became detached from the wall at one end. After drilling an extra hole at this end the batten remains detached despite the bracket screw being fully screwed in.
Will drilling a larger hole for a bigger, longer screw close the batten back to the wall?
Thank you in advance for any replies
abctc
Re: Wooden batten for curtain rail
by stoneyboy » Sun Jan 14, 2024 10:24 pm
Hi abctc,
The batten is there because the wall is not man enough for fixing curtain brackets direct. You will have to use new screws through the batten and into the wall using appropriate wall fixings, you could put these new fixings under where the curtain brackets will be located but it’s likely you will need numerous fixings.
abctc
by abctc » Tue Jan 16, 2024 11:13 am
Hi abctc,
Thank you Stoneboy for your reply.
What are 'appropriate wall fixings'? I'm a complete DIY novice.
Regards
abctc
by stoneyboy » Tue Jan 16, 2024 10:20 pm
Hi abctc,
Drill through the batten using a wood drill where you want it fixed back, change to a masonry drill and drill into the wall behind.
1…If the drill goes in easily for a short distance you probably have dry lined walls. If this is the case drive a plastic wall plug into the hole and put a screw in. Pump a water based grab adhesive between the wall and the batten before you screw it back.
2…. If the drill goes in easily but continues to drill into material you probably have aerated concrete blocks behind the batten. Fix as in 1.
3…. If the drill goes in but then gets difficult to go deeper you may have a concrete lintel above the window, ideally drill into the concrete then fix as in 1.
Hope that helps.
abctc
by abctc » Mon Jan 22, 2024 7:48 pm
Thanks again Stoneboy
That is much clearer.
Regards
abctc
It is currently Sun Dec 22, 2024 3:44 am
