Do I Need to Solder Galvansied Cable Safely due to Fumes?
Posted: Wed Jun 17, 2015 10:46 pm
by Nick33
I need to solder some 5mm galvanised wire cable into 5mm socketed fittings. I heard that this gives off dangerous fumes so should I wire-brush off the coating at the ends first or wear some sort of special mask?
Re: Do I Need to Solder Galvansied Cable Safely due to Fumes?
Posted: Thu May 03, 2018 7:10 am
by Sometimewoodworker
Nick33 wrote:I need to solder some 5mm galvanised wire cable into 5mm socketed fittings. I heard that this gives off dangerous fumes so should I wire-brush off the coating at the ends first or wear some sort of special mask?
Correct
Posted: Sun Oct 14, 2018 10:22 pm
When grinding or welding you can get what we call galv flue due to fumes, not sure hot enough with solder but the flux for lead free solder is also a problem, with a soldering iron and lead solder with care you should be OK, clearly trying not to breath in fumes.
