Brazing rebars to build small fruit cage
Help, advice and questions answered on all types of metal joinery
charlie101
by charlie101 » Fri May 14, 2021 1:07 am
I would like to connect a number of lengths of small diameter rebars together to create a fruit cage.
I can solder copper pipe but have no welding or brazing experience. I don't want to get involved with Oxygen.
I have read that Mapp can be used for 'light' brazing.
Does this sound doable?
Will Mapp give enough heat?
Will I have enough contact area to give 'strong' secure joints?
Any advice gratefully received.
Re: Brazing rebars to build small fruit cage
by stoneyboy » Sat May 15, 2021 11:11 pm
Hi charlie101,
You will probably do better hiring a small arc welder and buying a few rods.
NulDextrous
by NulDextrous » Wed Jul 21, 2021 1:08 pm
You can mig-weld rebar very easily, even with a cheap welder. I learned how to mig-weld using YouTube videos, and I can gas weld pretty well now. I get a mix of welding gas from HobbyWeld, and have a Mighty Mig 150. Very cheap set-up. I suggest you get something similar.
It is currently Thu Sep 19, 2024 2:38 am
