by Grandad »
Sat Jan 03, 2009 5:49 pm
Hi there Cornish Biker. Has everyone ignored you since October 25th?
I don't come on here very often, but I can perhaps help you with your query.
Starting from scratch. Over the years cavity walls have been sealed, vented, sealed, and so on, but if you have no visible vents (air bricks) in the outside of your cavity wall (I presume it is a cavity wall and not solid), then all you have to worry about is the need for your open fires, however occasional, to get sufficisnt air to burn properly. What goes up the chimney must come in from somewhere.
Cavity wall insulating contractors have recently told my neighbour they MUST drill a hole of about 7.5ins diameter and install a permanently open vent to ensure his open fire can get sufficient air to burn properly. This is covered under current Building Regulations.
If you DO have air bricks in the wall, they are likely to be to a larder, common just post WW2, or at very low level to vent the air space under a suspended wooden ground floor.
In these cases, the forming of a "Tunnel" across the cavity was a bit casual, to say the least, and there could be a risk of injected insulation blocking these vents.
Cheers. Grandad.
