Drainage Adjacent Proposed Extension
compoxx
by compoxx » Thu Apr 16, 2009 2:57 pm
I have planning permission for a single storey extension to the rear of the house. The existing drainage has an invert level of 300mm (very shallow). the house is a 1950's bungalow.
The drainage inspection chamber is only 750mm away from the corner of the exisitng bungalow.
Imagine a line from one corner of building where the MH cover is to the opposite diagonal where the corner of the new extension will be. extend this line a bit and thats the current line of the drain.
Question: how close can you be before deciding to move the drain? The drains are vitreus clay so I will renew the section in plastic anyway as fdn excavation will disturb.
If re-route drain not enough depth in the Inspection chamber at end of garden to make the connection at an adequate fall.
Any suggestions??
Sorry for long windedness. Without showing a drawing very diff to explain.
Thanks....
by stoneyboy » Sat Apr 18, 2009 1:35 pm
compoxx,
You should be able to discuss this with your LBI and reach an agreement.
holboob
by holboob » Fri Jun 12, 2009 1:57 pm
you can normally build as close as 100mm away
compoxx
by compoxx » Fri Jun 12, 2009 9:56 pm
Thanks Holboob,
I have decided to reroute the drain. Thought it will be better in the long run to divert the drainage alongside the extension rather than running underneath the slab.
